• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Expert Elite*
    TravisNave
    Re: Autodesk Installation Problems
    01-27-2012 11:40 AM in reply to: bone3
    Login as another user account with local admin rights and attempt to install again.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    Active Member
    hshdavidson
    01-27-2012 12:41 PM in reply to: bone3
    Im the other guy. Sorry to barge in on this discussion.  I tried to uninstall Visual C++, then reintalling Revit.  Now I have both Revit and A. Design Review as failed installations.  All 3 items have red Xs in front of them and the Revit and Autodesk Design Review have "failed" in front.  (last time only ADV had a "failed" in front of it)
    Ive attached my log-file below.
    Now what?
    *Expert Elite*
    TravisNave
    01-27-2012 01:05 PM in reply to: hshdavidson
    Looks to be failing on Visual C++ 2005 and 2010.  You have uninstalled both?
    Travis Nave
    Active Member
    bone3
    01-27-2012 01:14 PM in reply to: TravisNave
    Thank you! Everything works fine now. I installed without a problem 3Ds Max and 3D Maya. Thank you again!
    Active Member
    hshdavidson
    01-27-2012 01:16 PM in reply to: TravisNave
    No, I only uninstalled Visual C++  2010 (x86).  I have 21 installments of Visual C++ , up to and including -x64 Redistributable 10.0.40.219 (which looks like it was installed by SolidWorks)
    I imagine that the earlier versions have been superceded by the later and are no longer necessary.  Should I remove everything?  (8 are -2005)
    Thanks for the help.
    *Expert Elite*
    TravisNave
    01-27-2012 01:28 PM in reply to: hshdavidson
    No, if you have that many it's almost better just to modify your setup.ini file and delete the prerequisite check for those that won't install.  It's a little advanced, but it works.  If you can't figure it out, attach the setup.ini file and I'll see what I can do.
    Travis Nave
    Active Member
    hshdavidson
    01-27-2012 02:53 PM in reply to: TravisNave
    Yeah, I haven't got a clue on how to modify the setup.ini file.  I've attached it and woudl very much appreciate your help in modifying it.   Apparently I can't attach an .ini file to this post, so I jsut changed the extension to .txt.
     what does "Failed  Installation aborted, Result=1619" mean?
    thanks so much.
    Member
    wlaubner
    01-28-2012 09:29 AM in reply to: TravisNave
    I am getting the same error problem and cannot get beyond this failure.
    ACAD offers no support to someone who cannot get past this issue.
    Can you help.
    I am not a literate computer guy, so the terms, language does not help me and all I want is someone to walk me thru it.
    702-423-6280
    *Expert Elite*
    TravisNave
    01-28-2012 04:30 PM in reply to: bone3
    Autodesk provides support thru its Value Added Reseller partner channels.
    Please start a new thread. In the mean-time, use the search functionality to lookup potential answers.
    Travis Nave
    Member
    wlaubner
    01-28-2012 06:34 PM in reply to: bone3
    I did, and if you read everyone's comments it's obvious there is a problem given the common error message.
    Just answer with a solution not check with unknown parties. !
