I'm a student who decided to use the education program to make some animations. However I cannot do that. First I decided to try out 3Ds Max. Everything went ok till the installation itself. After a couple of tries I gave up and tried to install 3D Maya. Same problem. I meet the requirements. I have tried a couple of times following installation tutorials (deactivating antivirus program, closing other running programs, etc.) but they did not help. Burried myself in every possible article about such problems but couldn't find anything. I can't see what kind of error this is because when I try to check the logfile nothing happens. Here is everything I get when I try installing them (not only 3Ds Max but Maya, too):
If you don't know what the problem is, then at least tell me how to check the logfile, please.
Solved by TravisNave. Go to Solution.
Attach the log file, as it will include the reason for failure. If you cannot get to it from the GUI link in the failed install, then you can get to it manually by typing %TEMP% in your Start > Run box. Sort by date. The installation log file should appear near the top if it was the last thing you did.
I have a similar problem. I'm a student trying to install Revit Arch 2012 in WinXP64. I successfully installed AutoCAD 2012 first, then revit. The installer gets all teh way throuhg then tells me that install of all apps hvae failed. I tried (as per Autodesk site instructions: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617) to uninstall all Autodesk stuff etc. and then reinstalled AutoCAD. When I tried to install Revit the same thisn happened. Here is the log file:
2012/1/27:13:38:14 Administrator EVOL === Setup started on EVOL by Administrator ===
2012/1/27:13:38:14 Administrator EVOL Launch
2012/1/27:13:39:39 Administrator EVOL === Setup ended ===
2012/1/27:13:38:18 Administrator EVOL === Setup started on EVOL by Administrator ===
2012/1/27:13:38:18 Administrator EVOL Launch
2012/1/27:13:39:39 Administrator EVOL PageOpen LaunchDialog
2012/1/27:13:39:51 Administrator EVOL PageOpen LicenseDialog
2012/1/27:13:40:31 Administrator EVOL PageOpen ProductInfoDialog
2012/1/27:13:41:06 Administrator EVOL PageOpen ProductSelectionDialog2
2012/1/27:13:41:15 Administrator EVOL PageOpen FullProgressDialog
2012/1/27:13:41:15 Administrator EVOL Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Documents and Settings\Administrator\My Documents\Downloads\Autodesk_Revit_Architecture_2012_English_Win_32-64bit(1)\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\vcredist_x86_2010.log
2012/1/27:13:41:18 Administrator EVOL Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/1/27:13:41:18 Administrator EVOL PageOpen InstallCompleteDialog
2012/1/27:13:41:33 Administrator EVOL === Setup ended ===
Looks like installation of Visual C++ 2010 Redistributable failed. shall I try installing this first seperately?\]
scott
Chances are it is failing because a newer version is already installed. Rather you should uninstall the Visual C++ 2010 and then let the installer reinstall it on its own.
Thanks for the advise. So here is the logfile. To make it short: Errors 1622 and 1619 occur. What should I do?
Consider copying the entire contents of your media to a folder on your local hard drive and install from there. Make sure that you have local admin rights and that your anti-virus is disabled.
If this is a download, than it's already done for you. I had just noticed you were installing from F:\ and I wanted to make sure it was not a disc or USB media.
Login as another user account with local admin rights and attempt to install again.
Im the other guy. Sorry to barge in on this discussion. I tried to uninstall Visual C++, then reintalling Revit. Now I have both Revit and A. Design Review as failed installations. All 3 items have red Xs in front of them and the Revit and Autodesk Design Review have "failed" in front. (last time only ADV had a "failed" in front of it)
Ive attached my log-file below.
Now what?
Looks to be failing on Visual C++ 2005 and 2010. You have uninstalled both?
Thank you! Everything works fine now. I installed without a problem 3Ds Max and 3D Maya. Thank you again!
No, I only uninstalled Visual C++ 2010 (x86). I have 21 installments of Visual C++ , up to and including -x64 Redistributable 10.0.40.219 (which looks like it was installed by SolidWorks)
I imagine that the earlier versions have been superceded by the later and are no longer necessary. Should I remove everything? (8 are -2005)
Thanks for the help.
No, if you have that many it's almost better just to modify your setup.ini file and delete the prerequisite check for those that won't install. It's a little advanced, but it works. If you can't figure it out, attach the setup.ini file and I'll see what I can do.
Yeah, I haven't got a clue on how to modify the setup.ini file. I've attached it and woudl very much appreciate your help in modifying it. Apparently I can't attach an .ini file to this post, so I jsut changed the extension to .txt.
what does "Failed Installation aborted, Result=1619" mean?
thanks so much.
I am getting the same error problem and cannot get beyond this failure.
ACAD offers no support to someone who cannot get past this issue.
Can you help.
I am not a literate computer guy, so the terms, language does not help me and all I want is someone to walk me thru it.
702-423-6280
