HI,
I've downloaded the infrastructure suite to use as a free trial 2 days ago. Now it says "Product License Activation" and only gives you an option to click on Activate. During the install i selected the 30 day free trial, but it doesn't seem to help. I've uninstalled and re-installed and still get the same problem. Any ideas?
Hi Matt,
It appears as thou your 30 day trial period has expired. Unfortunately there's no way of getting around this issue, except to re-image/reformat you drive then reinstall the products.
As a side note, if there's an indvisual application you would like to test before making your purchase, you should be able to download that application and use the 30 day trial.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
