Installation & Licensing
Autodesk Entertainment Creation Suite Ultimate 2013 (Student) - LTU
2 REPLIES 2
AmberLD
336 Views, 2 Replies
I'm looking to buy the Autodesk Entertainment Creation Suite Ultimate 2013 using a student license, but I was wondering whether the License Transfer Utility feature as described here (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19107741&linkID=9240617#section5) would apply to this particular product? (Its name is not listed on the right-hand side of the webpage, which lists software that LTU applies to.)
I'm hesitant to buy this software if I would not be able to transfer it between computers, especially as it's likely I will need to replace my laptop in a couple of years but would still need to use these programs (and I may be buying a desktop in the next 5 years and prefer using the suite on that instead). Any suggestions?
Thank you so much for your time!
2 REPLIES 2
TravisNave
in reply to: AmberLD
Welcome to the forum, Amber.  You should have no problems transferring your license to a new computer using any Autodesk product.  Worst case, you can always reactivate manually thru the activation department.  Don't let this worry you.  Smiley Wink
Autodesk Forums:
AmberLD
Thanks so much for your prompt reply! That's very reassuring, and I'm glad to hear that it is indeed possible to transfer the license for this Autodesk product between computers.
Administrator Productivity
