How do you remove the educational banner on Autocad 2014 LT i downloaded it to do work while i waited till i could afford it, now this crap why did i even down load it for this reason?
You cannot. At least not legally. Your reseller may have a fee associated with resolving it legally. The educational version is very specific that it will stamp your work and that it is only for instructional use only and no commercial work should be done on it. You could have used a trial version for 30 days. Unfortunately, you will need to redo your work because you will not want to bring this into a commercial version and potentially poison all of your other work. Sorry, this is by design to prevent license circumvention.
http://www.autodesk.com/resellers/locate-a-reseller
That should help you. Good Luck!
