My students are supposed to install autoCAD 2010 french at home to do their homeworks. Since august 31st, they get this message when they download the software :
I am having a similar problem as well. But with Softimage 2011. I am able to download it and install it for the 30 day trial, but when I try to retrieve a serial number for it, i get the "temporarily out of serial numbers for this product" message.
As of now I have it installed with the 30 day trial, but I am going to need it for a school project due this May.
Will I be able to receive a serial number? Or should I just purchase the Autodesk Education Suite for about $400?
Thank you,
frank
i keep on having the same problem with maya too, and i have been waiting for quite a long time. it would be great if you guys can get more serial numbers soon!
thank you!
Hey,
I've been trying for a serial key and it says that you're all out. do you know when more will be coming in?
I installed the 30 day trial of Softimage, but wasn't able to optain a serial number, it gave me the run out message. But after 10 days or so, I noticed my serial number appear on the site. Just install the 30 day trial, and check back from time to time for the serial. Hopefully you guys get one too!
All - Please let me know which product(s) you are unable to obtain serial numbers for. If possible, please send an email to studentsupport@autodesk.com - include your full name and the school that you attend in your message. I'll then go ahead an manually generate your serial numbers for you.
Thank you!
Please reply directly to the email listed above your post.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi, I have posted a request for serial number to email above, but still no reply
Please the same error appears to me :S
i want to download t-splines and it tells me
"We apologize, we are temporarily out of serial numbers for this product. You may download and install the 30 day trial version. Return to this page prior to or at the expiration of your 30 day trial to obtain your serial number for activation."
my name
Alaa falih
my college
Jordan University Of Science And Technology
Hi afb19911103,
Is this the complete name of the software you are trying to download, Autodesk T-Splines Plug-in for Rhino? If so, I'll look into this and I'll get back to you once resolved.
Hello Alaa,
The message that you received was not actually an error, but by design as the system was out of serial numbers for that product. As mentioned, you should revisit the page (frequently) until one is available / obtained.
