I installed the Network License Manager for the above product folowing the documentation. The documentation it then said to install the Network License Activation Utility. This, however, did not exist as an installation option on the DVD. Using these forums I got the link to the autodesk registration page and got the product registered and a license file. I put this license file in a License folder within the Network License Manager folder. I then setup the LMTools to point to the lmrgd.exe file, the license file and the debug file. The LMTools version is 11.5
I then setup a deployment and made sure it was for our setup which is a single server network license. My test client installed the software perfectly but fails to pick up a license when Autocad is run. It returns the following error:-
Your application was not able to obtain a license because the FLEXnet license server manager could not determine where to find the licensing data it needs. It then asks to specify the license server or license file and fails.
Running LMTools The Server Diags > Perform Diagnostics comes up with following:-
"81000ESCSE_F" v1.000, vendor: adskflex
License server: PC254
floating license starts: 1-jan-1990, expires: 02-aug-2011
Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
A PACKAGE component must be specified.
Feature: 81000ESCSE_F
License path: C:\Program Files\Autodesk Network License Manager\License\ACAD2010license.lic;
FLEXnet Licensing error:-125,147
For further information, refer to the FLEXnet Licensing documentation,
available at "www.macrovision.com".
"80900ESCSE_2010_0F" v1.000, vendor: adskflex
This license can be checked out
This appears to point to the package line being wrong. But I have no idea where it might be wrong. This is how the Package line starts:-
PACKAGE 81000ESCSE_F adskflex 1.000 COMPONENTS=80900ESCSE_2010_0F \
OPTIONS=SUITE SUPERSEDE ISSUED=02-Sep-2009 SIGN="11F5 81B7 \
Can anyone help?
