Installation & Licensing
Autodesk Education Suite 2011 linux license server
7 REPLIES 7
Message 1 of 8
259 Views, 7 Replies
I have installed Network License Manager under linux without any problem. Now I want to provide does licenses for users. How to install on desktop computers (with windows) autocad with use of network license?
7 REPLIES 7
Message 2 of 8
DarrenP
you have to configure the installation for a network license
DarrenP
Message 3 of 8
in reply to: DarrenP
I tried to install it on my laptop and I do not see this option. I started installation from cd. In first window I clicked Install Products, then checked "AutoCAD 2011" -> next -> checked "I accept" in Licence Agreement -> next -> filled User and Product Information, chacked "I have my product information" radio button, filled serial number and product key -> next -> and in this window I see that my installation is standalone.
I haven't saw any network license option.
Message 4 of 8
TravisNave
In 2011, the default is stand-alone. You have to configure the product as a custom install to choose the network option.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 8
in reply to: TravisNave
Is it possible to this without use of other windows machine running as server? I have only one linux machine and I cannot have another used for sharing deployed installation folder.
Message 6 of 8
TravisNave
You don't have to create a deployment.  You can install a network version direct from disc.  You just have to choose configure and then choose the network option over stand-alone.
Autodesk Forums:
Message 7 of 8
Ok I see this option. I have one more question, Is it possible to use AutoCAD outside local network? Becouse I am currently out of office and when I put address in the name of server field I get the pop up window with information that this server name doesn't exist or is currently unavailable.
Message 8 of 8
TravisNave
Yes, you can borrow a license when you go offline.  Borrowing is under the Tools menu or also under Help>About>Product Information.  Simply pick the term length from the calendar pop-up and it will borrow the license for use off the network.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Autodesk Forums:
Administrator Productivity
