Installation & Licensing
Member
dcuccia
Message 1 of 13 (12,176 Views)
Autodesk Design Review 2013 Setup - Installation failed.
12176 Views, 12 Replies
10-29-2012 03:33 PM
I am on Windows 8 RTM x64. I am trying to install Design Review 2013, but the "internet connection" isn't being "found". My internet connection is fine. See the following:
TravisNave
Message 2 of 13 (12,153 Views)
Re: Autodesk Design Review 2013 Setup - Installation failed.
10-30-2012 07:07 AM in reply to: dcuccia
Please be aware that Autodesk products are not yet supported on Windows 8.  You should look to see if you can find a full download if available.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
dcuccia
Message 3 of 13 (12,132 Views)
10-30-2012 03:44 PM in reply to: dcuccia
Thanks.
Re: "You should look to see if you can find a full download if available."
I wasn't able to...any chance you could point me in the right direction?
David
Product Support
dembkod
Message 4 of 13 (12,099 Views)
11-01-2012 07:51 AM in reply to: dcuccia
dcuccia,
Hello. This program is not supported on Windows 8, so it may not be usable in your environment. There is an alternate download method, however. I have a link for you hat describes this here:
http://upandready.typepad.com/up_and_ready/2012/04/design-review-download-now-vs-additional-install-...
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Member
dcuccia
Message 5 of 13 (12,063 Views)
11-02-2012 04:21 PM in reply to: dembkod
dembkod wrote:
dcuccia,
David Dembkoski
David - that worked perfectly. I'm up and running, thanks very much! -David
sonablue
Message 6 of 13 (11,546 Views)
01-10-2013 03:28 PM in reply to: TravisNave
Hmm, but I'm getting the same error message... on a workstation that's WinXP 32-bit. I've tried the alternative download option as well. Any other ideas what I can do?
Thanks in advance.  ~Sona
Sona Greenberg
Product Support
dembkod
Message 7 of 13 (11,396 Views)
01-18-2013 10:57 AM in reply to: dcuccia
sonablue,
Hello. I would uninstall the program and wipe the residual folders for Design Review. There could be residual traces from a failed install.  First, run the MS Fixit utility and try to uninstall Design Review if it lists in this program.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Next, look for and delete residual traces that may be there. They will be clearly named and in a variety of places:
C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Program Files (x86)\Autodesk\
C:\Users\All Users\Autodesk\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
After all this is clean, make sure you have the MSI installer on your system.
http://www.microsoft.com/en-us/download/details.aspx?id=8483
Log in with an Admin account, turn off Windows UAC and Antivirus and give the install a go.
David Dembkoski
David Dembkoski
sonablue
Message 8 of 13 (11,340 Views)
01-22-2013 02:56 PM in reply to: dembkod
Hi dembkod,
Hmm, those look like folders in Win7, not WinXP. Nevertheless I'll look for their equivalent and clear what I find.
It's become less of a priority now that I've been switched to a Win7 machine myself (irony!), but a few other CAD users in my group are still using WinXP workstations and might like to see this resolved.
Sona Greenberg
New Member
bristleconedesign
Message 9 of 13 (10,992 Views)
02-12-2013 02:16 PM in reply to: dcuccia
David-
This worked for me as well.  Thank you for your help!
Member
CallawaySupport
Message 10 of 13 (1,065 Views)
05-12-2014 08:08 AM in reply to: bristleconedesign
Hello
I am getting similar errors as shown in the images on the 1st post.   I am using 64 bit windows 7 and I am in a Corporate environment, not at home.  Is it a firewall or other security issue that is blocking me?   My internet connection is fine.  Here is what I downloaded and the error I get.  I tried version 2012 also, got same type of error.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
