Installation & Licensing
Autodesk Civil 3D on a Mac server
3 REPLIES 3
341 Views, 3 Replies
Our server is aging and needs replaced.  Our in house IT guy wants to switch from PC to a Mac server.  Which essentially means we would switch to Macs.  Any suggestions?  All of our programs run in PC format and was wondering how this major change might affect how we are running right now.  Does Autodesk support Mac servers?
I just want to make sure I'm not missing something before I give my point of view on the idea.
3 REPLIES 3
DarrenP
you already have a thread on this
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Server-switch-PC-to-MAC/td-p/4293999
DarrenP
Yes, I was told to check the licensing and support of civil 3d running through a Mac.  Will Autodesk support a full Mac network environment with civil 3d running on parallel software?
TravisNave
Licensing will work.  But official Autodesk support on Parallels is laughable.  If you're going to run Windows on a Mac, you might as well stick with PCs.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
