Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autodesk AutoCAD Mechanical 2012 will not install
- Highlight
- Email to a Friend
- Report Inappropriate Content
I'm currently trying to install AutoCAD Mechanical 2012 for a client. We have been trying for about 2 and a half weeks now to install the Product Design Suite Ultimate 2012 and every time it hang or fails while installing AutoCAD Mechanical 2012. We first tried to install from the USB stick. That didn't work. We did manage to install every other component piece by piece but AutoCAD Mechanical 2012 just fails every time. I downloaded it from the Autodesk website and tried to install it from that but it still will not install. This program is going to drive me nuts! Please help we would like to get this system to our customer as soon as possible.
Re: Autodesk AutoCAD Mechanical 2012 will not install
- Highlight
- Email to a Friend
Thanks for including the log. The actual error that's holding up the install is the following:
CheckForACADExistence. Return value 3.
This can easily be resolved by verifying that there is not Mechanical 2012 directory already present on the hard drive in the install path, as for example, c:\Program Files\Autodesk\AutoCAD Mechanical 2012.
Remove or rename this directory and also be sure that the following key in the Registry is either removed or renamed:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.2
Then launch the installer again and see if it will then succeed. Let me know how it goes.
Also, it's always strongly recommended to backup the registry prior to making any edits.
Alison
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Alison Gangler
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Thank you for the tip. I was finally able to get AutoCAD Mechanical 2012 Installed. I deleted that folder and removed some registry entries tied to Mechanical. I was unable to find the specific one you suggested...but it worked out in the end. I believe the installer we had on the flash drive may have been corrupt, because we first tried to install from the USB again and it failed. The download from the Autodesk website did work though. I noticed that the installation size changed from around 1GB when it was failing to around 2.5GB when it finally installed.
Thank you again for your assistance.
- Highlight
- Email to a Friend
Glad it worked!
Cheers,
Alison
Alison Gangler
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Good evening,
I´m also having trouble installing Autodesk AutoCAD Mechanical 2012 and Inventor Pro 2012.
In attach i´m sending the error message and logs.
Any ideas how to solve?
André Gouveia.
- Highlight
- Email to a Friend
Please refer to this Technical Solution regarding this error:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Cheers,
Alison
Alison Gangler
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi again,
I tried it but i can´t find the file ProductInformation.pit
The link refers to 2 different errors: "adlmPITSetProductInformation failed" and "adlmPITRemoveProductInformation failed"
I get the first error and i realy can´t find the file or folder in the solution you refered me to.
Can you help?
- Highlight
- Email to a Friend
It's a hidden folder. Go there by typing the path directly or by turning on your hidden files and folders in Windows Explorer.
%PROGRAMDATA%\Autodesk\Adlm
My Top Contributions to the Discussion Groups:
FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files |
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
