Installation & Licensing
Autodesk Activation window broken
4 REPLIES 4
411 Views, 4 Replies
when ever I try and activate MAYA the doesn't load properly and all i see is this. have tried redownloading and reinstalling but to no avail. any ideas?
4 REPLIES 4
joane.bonghanoy
Hi scorch267,
Please click here for the resolution of this error.
Let us know if it worked for you or if you still have the same issue.
Joane Bonghanoy
in reply to: joane.bonghanoy
I have tried all the suggestions (except number 1 because IE8 isn't available on windows 7) and nothing has worked. I am now trying IE10 and will get back to you.
TravisNave
Others have had success from the multiple items in this post:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Updating to IE 10 fixed the problem thankyou for the help.
Administrator Productivity
