Installation & Licensing
Autodesk 3ds max (2013) failed to install
1 REPLY 1
794 Views, 1 Reply
hi!
i would like to have some help regarding  my autodesk 3ds max that i have downloaded recently
uhmm i really dont know how or why the installation keep saying to me that there's some products that had failed to install aaahh please someone help me
here is the log
2013/3/26:14:45:05    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:14:45:05    Desktop    DESKTOP-PC    Launch
2013/3/26:14:45:26    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:15:54:04    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:15:54:04    Desktop    DESKTOP-PC    Launch
2013/3/26:15:54:27    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:15:54:11    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:15:54:11    Desktop    DESKTOP-PC    Launch
2013/3/26:15:54:28    Desktop    DESKTOP-PC    PageOpen    LaunchDialog
2013/3/26:15:54:45    Desktop    DESKTOP-PC    PageOpen    LicenseDialog
2013/3/26:15:54:49    Desktop    DESKTOP-PC    PageOpen    ProductInfoDialog
2013/3/26:15:56:12    Desktop    DESKTOP-PC    PageOpen    ProductSelectionDialog2
2013/3/26:15:56:26    Desktop    DESKTOP-PC    PageOpen    FullProgressDialog
2013/3/26:15:56:26    Desktop    DESKTOP-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Desktop\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/3/26:15:57:14    Desktop    DESKTOP-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2013/3/26:15:57:14    Desktop    DESKTOP-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/3/26:15:57:53    Desktop    DESKTOP-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2013/3/26:15:57:53    Desktop    DESKTOP-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/3/26:15:58:15    Desktop    DESKTOP-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2013/3/26:15:58:15    Desktop    DESKTOP-PC    Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/26:16:03:54    Desktop    DESKTOP-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/3/26:16:03:54    Desktop    DESKTOP-PC    Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x86.exe /q /norestart
2013/3/26:16:12:29    Desktop    DESKTOP-PC    Install    .NET Framework Runtime 4.0 KB2468871    Succeeded
2013/3/26:16:12:30    Desktop    DESKTOP-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/26:16:14:15    Desktop    DESKTOP-PC    Install    DirectX® Runtime    Succeeded
2013/3/26:16:14:16    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:16:15:06    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/26:16:15:06    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:16:15:37    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/26:16:15:37    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:16:26:59    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Failed    Installation aborted, Result=1603
2013/3/26:16:27:23    Desktop    DESKTOP-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/26:16:28:10    Desktop    DESKTOP-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/26:16:28:11    Desktop    DESKTOP-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/26:16:28:11    Desktop    DESKTOP-PC    Rollback    .NET Framework Runtime 4.0 KB2468871    Failed    Installation aborted, Result=1619
2013/3/26:16:28:11    Desktop    DESKTOP-PC    Rollback    .NET Framework Runtime 4.0    Failed    Failure is ignored, Result=1619
2013/3/26:16:28:11    Desktop    DESKTOP-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2013/3/26:16:28:11    Desktop    DESKTOP-PC    Rollback    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2013/3/26:16:28:11    Desktop    DESKTOP-PC    Rollback    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
2013/3/26:16:28:54    Desktop    DESKTOP-PC    PageOpen    InstallCompleteDialog
2013/3/26:16:41:21    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:16:47:48    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:16:47:48    Desktop    DESKTOP-PC    Launch
2013/3/26:16:47:48    Desktop    DESKTOP-PC    CommandLine
2013/3/26:16:48:01    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:17:33:45    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:17:33:45    Desktop    DESKTOP-PC    Launch
2013/3/26:17:34:20    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:17:33:56    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:17:33:56    Desktop    DESKTOP-PC    Launch
2013/3/26:17:34:21    Desktop    DESKTOP-PC    PageOpen    LaunchDialog
2013/3/26:17:49:05    Desktop    DESKTOP-PC    PageOpen    LicenseDialog
2013/3/26:17:49:08    Desktop    DESKTOP-PC    PageOpen    ProductInfoDialog
2013/3/26:17:51:09    Desktop    DESKTOP-PC    PageOpen    ProductSelectionDialog2
2013/3/26:17:51:27    Desktop    DESKTOP-PC    PageOpen    FullProgressDialog
2013/3/26:17:51:27    Desktop    DESKTOP-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/26:17:56:52    Desktop    DESKTOP-PC    Install    DirectX® Runtime    Succeeded
2013/3/26:17:56:52    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:17:58:13    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/26:17:58:13    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:17:58:38    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/26:17:58:38    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:17:58:47    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Failed    Installation aborted, Result=1603
2013/3/26:17:59:12    Desktop    DESKTOP-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/26:17:59:50    Desktop    DESKTOP-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/26:17:59:50    Desktop    DESKTOP-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/26:18:00:04    Desktop    DESKTOP-PC    PageOpen    InstallCompleteDialog
2013/3/26:19:31:08    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:21:18:18    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:21:18:18    Desktop    DESKTOP-PC    Launch
2013/3/26:21:18:50    Desktop    DESKTOP-PC    === Setup ended ===
2013/3/26:21:18:28    Desktop    DESKTOP-PC    === Setup started on DESKTOP-PC by Desktop ===
2013/3/26:21:18:28    Desktop    DESKTOP-PC    Launch
2013/3/26:21:18:51    Desktop    DESKTOP-PC    PageOpen    LaunchDialog
2013/3/26:21:19:55    Desktop    DESKTOP-PC    PageOpen    LicenseDialog
2013/3/26:21:19:59    Desktop    DESKTOP-PC    PageOpen    ProductInfoDialog
2013/3/26:21:21:19    Desktop    DESKTOP-PC    PageOpen    ProductSelectionDialog2
2013/3/26:21:22:10    Desktop    DESKTOP-PC    PageOpen    FullProgressDialog
2013/3/26:21:22:10    Desktop    DESKTOP-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/26:21:28:09    Desktop    DESKTOP-PC    Install    DirectX® Runtime    Succeeded
2013/3/26:21:28:10    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:21:29:34    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/26:21:29:34    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:21:30:07    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/26:21:30:07    Desktop    DESKTOP-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:21:37:24    Desktop    DESKTOP-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Failed    Installation aborted, Result=1603
2013/3/26:21:38:03    Desktop    DESKTOP-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/26:21:38:47    Desktop    DESKTOP-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/26:21:38:47    Desktop    DESKTOP-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
1 REPLY 1
TravisNave
You might have to redownload your product, as it is warning you that files are missing.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
