Hello, I downloaded and installed 3Ds Max on Windows 8 - 64bit. Then I tried start 3Ds Max. I was suprised, it didnt start. It wrote 3ds Max Error Report. Can you help me, please? I tried all (run as admin, compatibility windows 7, ...) Help, please. I need it.
Lukis37 ,
Hello. The reboot causing an issue is strange. I am wondering if perhaps some service is starting up after a reboot and affecting the installation. I would take a look at your Antivirus or any similar programs and see if there is something that perhaps would be starting and could affect the program. If you could disable your Antivirus, or uninstall to test, it may be worth the effort. Also, I would see if the behavior is the same if you change the user account you are trying to use. If one account works and the other causes errors, there may be a profile conflict of some type.
Thank you for taking part in our community!
Solved... before I start 3Ds Max, I must delete folder Autodesk from Roaming 🙂 You can lock this or something... 😄
