Hi there,
Just would like to know if there is an update for the follwoing hotfix for the 2012 products, experienced the same on Civil 3D 2012 64 Bit.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13401936&linkID=9240818
AMD Athlon(tm) X2 Dual-Core QL-65 2.10GHz processor; 3 GB RAM; Windows 7 Professional 64-bit
Best Regards,
Andre
Solved by HelenChen-Autodesk. Go to Solution.
If your problem is just the issue you mentioned in the subject title - Autodesk 2012 Product - Activate Button Missing, see below post to see whether it can be helpful:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Otherwise, please share with us more about what problems you have and any screenshot does helpful for us to understand your problem. Thank you.
Helen
Good morning,
Attached is the screenshot, and will give feedback later today if this solution resolved the problem.
Thanks for the help.
Best Regards,
Andre
Please create a new user account with ADMIN and UAC turned off. This is very odd. I looks like a permissions issue and the wizard can't view the files.
