I have setup a 2011 64 network deployment that works fine with our shared network licenses. When I try to do a 32 bit deployment the installation seems to go fine but when trying to run AutoCAD on the workstation it acts as a standalone installation and asks you to activate. It then insists that the serial number is not valid. I also tried to do a deployment for 2010 and encountered the same error for that network serial number also. It gives the error as "Error 123".
Solved by TravisNave. Go to Solution.
Seems as though your network deployment is created as a stand-alone install rather than a network install. You may need to modify or remake your deployment image.
Ok. That was it. I had to click on configure when I got to the create deployments page where standalone was the default option. I don't recall doing that with the 64 bit install ...
Glad you got it up and running. The 2012 products ask you instead of making you search for it, which is a huge plus.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
OK, thanks.
Now I'm wondering if I used the standalone serial number in the 64 bit deployment I used and that is why it is working fine. Guess I better check that!
So long as it is a valid serial number and it is configured as a network install, it really shouldn't matter. It will grab the license from the NLM.
