At the moment you have the standalone version of AutoCAD installed, that
version does not know how to see your license server. You need to uninstall
AutoCAD then reinstall using a deployment created for network license usage.
The required procedure is described in the Network Administrator's Guide
which is on your AutoCAD CD.
Jerry Milana,
Autodesk Consulting
"deeter72" wrote in message
news:27686208.1093882786633.JavaMail.jive@jiveforum2.autodesk.com...
> so, should i do the net setup before I install Autocad? WHen I try to
install the netsetup part, I cant pick the first option. It tells me I have
a stand alone version. But when I use the lmtools utility, it tells me I
have 2 floating licenses that can be checked out. Does this make any sense?
