Installation & Licensing
Autocad trial version missing source file
3 REPLIES 3
westerly
546 Views, 3 Replies
I am attempting to download a 30 day trial of autocad. The download will go so far and then give me a "source file not found" error message. Does anyone know how to correct this? I need to start working on this asap. Thank you!!
3 REPLIES 3
TravisNave
in reply to: westerly
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Autodesk Forums:
westerly
in reply to: TravisNave
Thank you so much!! I changed to IE and it went just fine. Thanks again!
Hi, I have the same problem trying to download the free trial version of Autodesk Ecotect. However, all the workarounds (other browser: tried IE, Chrome & Firefox) (bypass Download Manager and download by browser) all give the same problem of "source file not found". Any ideas?
Thanks very much! Regards, Inge
Administrator Productivity
