Hello Everyone
I want to install a windows based server, using Windows 2008 64 bit Foundational, with 6 thin client connected to it.
Thanks in advance
Regards
David
you may want to look into a citrix enviroment: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
what your trying to do is not the way autocad is designed to work
DarrenP
Darren is right. You will want to look at the Citrix solution as it is the only supported licensed mode. All other implementations violate the license agreement.
