Hi guys,
A lot of architects, building engineers and I want to know, if it is possible to run AutoCad Architecture under useable conditions on a Surface Pro 2. The minimum system requirements are matching the power of the Surface Pro 2, but this says nothing because my actual PC is not running smooth beyong it matches the optimal system requirements. Is it possible, that somebody can make a video by runnig this software? Would it be possible to show the fps during using AutoCad Architecture? All in all I want to mention that I know that the screen is very small, but would it be possible to run AutoCad Architecture with the power of the Surface Pro 2 on an extern monitor.
I am looking forward to hear from you!
Your faithfully,
Mario
