Im in the process of setting up computers at our office for using autocad 2012. We are making the jump from 2000 but need to customize the newer version to match what we had. For instance, ive adjusted the pgp file for our offices standard quick keys.
My question is though.... When i installed autocad i installed it under my user log-on. Files such as the pgp file are under c:\user\"user name"\appdata\roaming\autodesk\aca 2012\enu\support. If i get everything setup such as pgp and templates, it is only setup when i log on. If anyone else logs on i have to redo the settings. This seems to be the default. Since the office wants the freedom to log onto other peoples computers, it would be a pain to setup every possible user on every computer.
Would this problem be solved by installing as admin or is there another solution.
Autocad 2012
windows 7 64 bit
