Hello.
I downloaded and extracted Autocad 2014, everything went great. When the installation prosess began, however, it just ended in a few minutes telling me that the product failed to install.
I tried several times, searched on the internet for various solutions, but nothing worked for me.
I attach the log file and hope you will be able to help me as it is quite urgent.
Thanks, Kamila
Hi Kamila and welcome to the Autodesk Community!
Thank you for including your log file - "Failed Installation aborted, Result=1603"
This error can be tough, but luckily we have a variety of troubleshooting solutions to help you through it:
If you follow all of these troubleshooting steps and the issue persists, please respond to this information with further details.
Thank you!
Right, so here's what I've done and it WORKED 🙂
(I had no Autodesk products installed before as I'm working on a brand new win8 PC.)
I uninstalled the Mocrosoft Visual C++ (all of it)
It still showed problems with .net framework language pack in the log, as it was installed before with win8 so I followed the instructions here:
The video really helps 🙂
After modifying the setup.ini file properly everything went smoothly.
Thanks for your help, Jessica!
Regards, Kamila
