Hi, I am trying to reinsall Autocad because I have recently changed from Windows 8 to Windows 7 Ultimate (x64) Upon opening the installer, I get a failed connection error. I have opened up all of my http and https ports along with disabling UAC. When I launch the installer, I stay on the page without clicking anything else, yet I am still reciving the error. I would greatly appreciate some help as I have no idea what I am doing wrong.
Solved by surfacelane. Go to Solution.
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
