I am having the same problem downloading AUTOCAD, that I had with Autodesk Inventor Pro. It appeared to download correctly, and I have the serial # and product key for it, but the program cannot be found. My Autodesk folder only shows the files for the Inventor Pro I downloaded a month or so ago. I was sent a different link to download the Inventor Pro previously, and that worked fine. Is there a separate link I can use for the Autocad download? Thanks, Norm Daniel
Hi ndani857:
Help me understand you better. You downloaded Autodesk Inventor Professional and you would like to install AutoCAD as a standalone product. However, you cannot find it anywhere in your machine and you would like to have a link to download it separately, am I correct? Please clarify.
Thank you for your assistance.
After posting, I realized that I had not included all of the info that was neaded. However, I was able to locate the file late last night, and downloaded it just fine.
Have sent a fax to request assistance with activating, so hoping to hear back soon.
Thanks again for your reply!
Norm
Hi ndani857,
I'm not sure what fax number you have used to request activation assistance, but none of our activations are done via fax. Please go to this web form to activate your product, or contact the activation department at 800-551-1490.
