Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Autocad Suite shows one of the programs is already installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I wanted to try the cad Infrastructure Suite. Unfortunately while the suite was still loading I made the foolish mistake of opening Autocad Civil which had completed its installation. When Autocad Civil began opening it froze followed by a message from the installation of the suite stating it could not continue until all Autodesk programs were closed. I tried with no avail to get Civil to close so I was forced to cancel the suite installation (which “kind of removed” Autocad Civil). Every time that I have tried to reinstall the suite it shows that civil is already installed. Civil does not show up under the Windows Uninstall program but the folder was present under Program Files. I’ve tried the uninstall/reinstall guides by Autodesk but nothing has helped. I have deleted everything in the registry that is named “Autocad Civil” and still nothing!!!!. In the process I have had to wipe my licensed versions of cad.
I really don’t want to format the computer for a trial. Does anyone know where the file is located that is telling the suite the Autocad Civil is still installed?
Re: Autocad Suite shows one of the programs is already installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensi
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Autocad Suite shows one of the programs is already installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Eric.rudd,
Hello. There are likely 2 keys that you will need to remove, that would cause this type of error. One is for the program and one is for the language pack. Assuming you are talking about 2013:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Prod
Delete these, then try to install.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Mr. Dembkoski,
Thankyou of your help. Unfortunately I had removed to much out of the registry and my reg backup failed (first time I have ever seen that). I wiped the computer and reinstalled the trail version. Everything went great this time except when I open any of the trial versions it asks to activate the software and requires a S/N to proceed. Any ideas?
ER
