Solved by hashim.mundol. Go to Solution.
Please use the /W switch as documented here.
/W will make the calling program to wait till the installation is complete to move on to the next one.
Please note, if the scripted installation doesn't update GUIDs properly VBA installer might not find the right target application.
So please follow one of the method in the documentation.
http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff-e569a012180ce589145cc.htm
Thanks Hashim,
That worked perfectly. Is there a document listing the controls for the installers?
Appreciate your help.
Guy
This sample script covers some of the parameters which can be used.
http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.htm
