Installation & Licensing
Distinguished Contributor
guyh
Message 1 of 4 (222 Views)
Autocad Mechanical 2011 - Last file installed or reg key?
222 Views, 3 Replies
04-17-2012 12:11 PM
I am writing a batch file to try automate the install of Autocad Mechanical 2011 then subsiqently the VBA enabler. In the batch file I need to delay the vba install until the acad install has finished. I want to know which is the last process in the language pack install that I can check in batch file before proceeding to the next step by using a goto loop. Cheers, Guy
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
Product Support
hashim.mundol
Message 2 of 4 (213 Views)
Re: Autocad Mechanical 2011 - Last file installed or reg key?
04-19-2012 06:51 AM in reply to: guyh
Please use the /W switch as documented here.
/W will make the calling program to wait till the installation is complete to move on to the next one.
Please note, if the scripted installation doesn't update GUIDs properly VBA installer might not find the right target application.
So please follow one of the method in the documentation.
http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff-e569a012180ce589145cc.htm
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
guyh
Message 3 of 4 (205 Views)
04-20-2012 01:58 AM in reply to: hashim.mundol
Thanks Hashim,
That worked perfectly.  Is there a document listing the controls for the installers?
Appreciate your help.
Guy
AutoCADM 2011 SP2
Product Support
hashim.mundol
Message 4 of 4 (203 Views)
04-20-2012 02:12 AM in reply to: guyh
This sample script covers some of the parameters which can be used.
http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.htm
Hashim Mundol
