• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    Autocad Mechanical 2011 - Last file installed or reg key?
    161 Views, 3 Replies
    04-17-2012 12:11 PM
    I am writing a batch file to try automate the install of Autocad Mechanical 2011 then subsiqently the VBA enabler. In the batch file I need to delay the vba install until the acad install has finished. I want to know which is the last process in the language pack install that I can check in batch file before proceeding to the next step by using a goto loop. Cheers, Guy
    AutoCADM 2011 SP2
    XP 32-Bit SP3
    Please use plain text.
    Product Support
    Re: Autocad Mechanical 2011 - Last file installed or reg key?
    04-19-2012 06:51 AM in reply to: guyh
    Please use the /W switch as documented here.
    /W will make the calling program to wait till the installation is complete to move on to the next one.
    Please note, if the scripted installation doesn't update GUIDs properly VBA installer might not find the right target application.
    So please follow one of the method in the documentation.
    http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff-e569a012180ce589145cc.htm
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    04-20-2012 01:58 AM in reply to: hashim.mundol
    Thanks Hashim,
    That worked perfectly.  Is there a document listing the controls for the installers?
    Appreciate your help.
    Guy
    AutoCADM 2011 SP2
    XP 32-Bit SP3
    Product Support
    04-20-2012 02:12 AM in reply to: guyh
    This sample script covers some of the parameters which can be used.
    http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.htm
    Hashim Mundol
