Installation & Licensing
New Member
dlines18
Message 1 of 4 (353 Views)
Autocad MEP 2013 Won't Install
353 Views, 3 Replies
09-04-2013 11:34 AM
I have installed Autocad 2013 and the fabrication for 2013 but when i try MEP it gets to the end of the install process and says installation failed. this is the log file from the installation if anyone could help me out. I'm losing a lot of money not being able to work on drawings requiring MEP, so advice soon would be much appreciated! Thanks
TravisNave
Message 2 of 4 (350 Views)
Re: Autocad MEP 2013 Won't Install
09-04-2013 11:46 AM in reply to: dlines18
Welcome to the community.
It's actually installing successfully, then bombing on Cloud Sync.  After that it rolls back.
Install	Autodesk Cloud sync	Failed	Installation aborted, Result=1603
It could be that you had a previous version or a beta version installed:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18744845&linkID=9240617
Or you can choose not to install it or uninstall it:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18966285&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
dlines18
Message 3 of 4 (324 Views)
09-05-2013 06:57 AM in reply to: TravisNave
Thank you so much you are a saviour! Worked first time
New Member
BM_7
Message 4 of 4 (262 Views)
09-12-2013 04:13 AM in reply to: TravisNave
How is it going Travis?
I just saw your post and was wondering if you could possibly help me out of a fix. II have a problem I haven't found a solution for yet and I saw your post so I thought I'd chance my arm and ask you. I have installed CAD MEP 2013 on to a computer. We have the Plant Design Suite installed on the computer. I initially ran the app load and take off command in AutoCAD, I should have run it in AutoCAD Plant3D 2013 unknowingly. I uninstalled MEP and re-installed it to find it still would not work in Plant. When I type appload in Plant and select the CADmep19x64.arx file to load I get the following message:
"Unhandled Exception 0 (Access Violation Reading 0x0660) at address A4525E69h"
MEP works fine in AutoCAD but I need it to work in Plant 3D not CAD.
I was hoping you might have a fix for the problem or a possible work around. If you dont know could you point me in the right direction?  Any help or guidance would be greatly appreciated.
Cheers,
Brian.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
