Installation & Licensing
New Member
niall.shanahan
Message 1 of 8 (1,156 Views)
Autocad LT 2014 uninstall and reinstall on new computer.
1156 Views, 7 Replies
10-15-2013 07:41 AM
I want to uninstall Autocad LT 2014 from a DT and reinstall it on a new DT. What do I have to do? Is it enough to uninstall using the Windows control panel, or are ther extra steps? how do I ensure that the licence is tied to the new DT?
Patricia.Cuizon
Message 2 of 8 (1,150 Views)
Re: Autocad LT 2014 uninstall and reinstall on new computer.
10-15-2013 08:13 AM in reply to: niall.shanahan
Hello niall.shanahan!
Welcome to the forums!
To make sure the license is tied to the new desktop, you will need to use the License Transfer Utility to move the license from the old computer to the new one before uninstalling it. The instructions for the License Transfer Utility (LTU) can be found here.
Let me know if this helps.
Patricia Cuizon
New Member
niall.shanahan
Message 3 of 8 (1,143 Views)
10-15-2013 08:21 AM in reply to: niall.shanahan
Thanks Patricia.
So, basically export the licence via the instructions you provided, install the software to the new computer from disc and finish the process by importing the licence to the new DT. Sounds simple.
Patricia.Cuizon
Message 4 of 8 (1,135 Views)
10-15-2013 08:39 AM in reply to: niall.shanahan
You're welcome, niall.shanahan.
Yes, that's all you have to do. Good luck!
Patricia Cuizon
jon
New Member
jon
Message 5 of 8 (743 Views)
11-05-2013 08:32 AM in reply to: niall.shanahan
Can I use this technique to use LT 2014 on my desktop and my laptop, ie use LTU to switch between the two, or is it limited in the number of uses?
Jon
philip.s
Message 6 of 8 (730 Views)
11-05-2013 09:26 AM in reply to: jon
Hi Jon!
Correct that there is not a limit on LTU uses, however, I also would like to point out that  most license types (excluding educational) allow the software to be installed and activated on 2 separate machines, as long as you are the sole user and the 2 aren't used concurrently. Check out the the Autodesk Product Activation FAQ for more info.
Philip Schmelzer
jon
New Member
jon
Message 7 of 8 (705 Views)
11-06-2013 09:27 AM in reply to: niall.shanahan
Many thanks for that.  It was very helpful and very prompt
Jon
philip.s
Message 8 of 8 (697 Views)
11-06-2013 10:39 AM in reply to: jon
Our pleasure!
Philip Schmelzer
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
