Installation & Licensing
Autocad LT 2013 Failed to Install .net Framework Runtime 4.0
5 REPLIES 5
5253 Views, 5 Replies
I am having problems installing AutoCad Lt 2013.  It fails during the .Net installation.  I am using Windows 7 Ultimate, 64 bit.  I have used AutoCad Lt 2012 with Windows 7 Ultimate 64 bit before... I am installing from my hard drive using AutoCADLT_2013_English_Win_64bit.exe.  I have all Windows updates installed.  I have run the installation as administrator, used the cmd prompt/system file checker utility to repair/replace any damaged system files...etc...etc...  I am at a loss now.
Here is a copy of the log file:
2012/6/12:11:10:02 Work JODY-HP === Setup started on JODY-HP by Work === 2012/6/12:11:10:02 Work JODY-HP Launch 2012/6/12:11:10:05 Work JODY-HP === Setup ended ===
2012/6/12:11:10:02 Work JODY-HP === Setup started on JODY-HP by Work === 2012/6/12:11:10:02 Work JODY-HP Launch 2012/6/12:11:10:04 Work JODY-HP PageOpen LaunchDialog   2012/6/12:11:10:06 Work JODY-HP PageOpen LicenseDialog   2012/6/12:11:10:08 Work JODY-HP PageOpen ProductInfoDialog   2012/6/12:11:10:24 Work JODY-HP PageOpen ProductSelectionDialog2   2012/6/12:11:10:26 Work JODY-HP PageOpen FullProgressDialog   2012/6/12:11:10:27 Work JODY-HP Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCADLT_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/6/12:11:11:02 Work JODY-HP Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
5 REPLIES 5
I have also rolled my machine back to Windows 7 Home Premium and get the same results.
Additional things tried:
-Deleted content of the temp folder
-used the .net clean-up utility to completely remove all versions of .net
TravisNave
Then you might have to install .NET 4 manually and then modify the setup.ini file to remove the prerequisite check for .NET Framework.
You can find the process on how to do this on my response here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
titti
in reply to: TravisNave
Well, i have exactly the same problem. The installation of Autocad Architecture 2013 fails, because of a failing install of .NET Framework Runtime 4.0. I'm running Windows XP SP3.
I tried uninstalling .NET Framework 4.0 but the install still fails.
Any other suggestions?
TravisNave
in reply to: titti
Yes, remove the prerequisite check for .NET Framework in the setup.ini file.  My instructions were given in my link above.
Autodesk Forums:
Administrator Productivity
