Installation & Licensing
New Member
Message 1 of 1 (793 Views)
Autocad LT 2012 Windows 7 Pro 64 Bit install failing
793 Views, 0 Replies
10-12-2012 09:16 AM
Please help. I switched OS from Windows 7 Pro 32 bit to W7 Pro 64 bit.  Autodesk sent new download file AutoCAD_LT_2012_English_Japanese_Win_64bit.   I was having issues with the installation of Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603.   I removed other verstions of C++ both 2008 and 2010 and tried install again and I now seem to be having another issue.  I tried the install twice and still the same issue see below.  Please help.
TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:06:36    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:14:07:04    TRAndrews    TRANDREWSOFFICE    PageOpen    LaunchDialog
2012/10/11:14:07:33    TRAndrews    TRANDREWSOFFICE    PageOpen    LicenseDialog
2012/10/11:14:07:37    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductInfoDialog
2012/10/11:14:11:25    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductSelectionDialog2
2012/10/11:14:11:37    TRAndrews    TRANDREWSOFFICE    PageOpen    FullProgressDialog
2012/10/11:14:11:37    TRAndrews    TRANDREWSOFFICE    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_6
4bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\TRANDR~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/11:14:11:43    TRAndrews    TRANDREWSOFFICE    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Succeeded
2012/10/11:14:11:43    TRAndrews    TRANDREWSOFFICE    Installing Autodesk® Design Review:  TRANSFORMS="C:\Users\TRANDR~1\AppData\Local\Temp\_AI2DF2.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:12:29    TRAndrews    TRANDREWSOFFICE    Install    Autodesk® Design Review    Succeeded
2012/10/11:14:12:29    TRAndrews    TRANDREWSOFFICE    Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:14:13:03    TRAndrews    TRANDREWSOFFICE    Install    DirectX Runtime    Succeeded
2012/10/11:14:13:03    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:13:35    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012    Succeeded
2012/10/11:14:13:35    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:14:07    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:14:14:07    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:14:16    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Content Service    Succeeded
2012/10/11:14:14:17    TRAndrews    TRANDREWSOFFICE    Installing AutoCAD LT® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI2DF2.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:19:42    TRAndrews    TRANDREWSOFFICE    Install    AutoCAD LT® 2012    Failed    Installation aborted, Result=1603
2012/10/11:14:19:47    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Content Service    Succeeded
2012/10/11:14:20:00    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:14:20:16    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012    Succeeded
2012/10/11:14:20:16    TRAndrews    TRANDREWSOFFICE    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/11:14:20:22    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk® Design Review    Succeeded
2012/10/11:14:20:22    TRAndrews    TRANDREWSOFFICE    Rollback    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1619
2012/10/11:14:20:22    TRAndrews    TRANDREWSOFFICE    PageOpen    InstallCompleteDialog
2012/10/11:14:22:25    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:14:39:07    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:39:07    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:14:40:08    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:14:39:08    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:39:08    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:14:40:10    TRAndrews    TRANDREWSOFFICE    PageOpen    LaunchDialog
2012/10/11:14:40:39    TRAndrews    TRANDREWSOFFICE    PageOpen    LicenseDialog
2012/10/11:14:40:53    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductInfoDialog
2012/10/11:14:41:09    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductSelectionDialog2
2012/10/11:14:41:11    TRAndrews    TRANDREWSOFFICE    PageOpen    FullProgressDialog
2012/10/11:14:41:11    TRAndrews    TRANDREWSOFFICE    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/10/11:14:41:41    TRAndrews    TRANDREWSOFFICE    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2012/10/11:14:41:41    TRAndrews    TRANDREWSOFFICE    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/10/11:14:41:50    TRAndrews    TRANDREWSOFFICE    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x64)    Succeeded
2012/10/11:14:41:50    TRAndrews    TRANDREWSOFFICE    Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:14:42:32    TRAndrews    TRANDREWSOFFICE    Install    DirectX Runtime    Succeeded
2012/10/11:14:42:32    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:43:01    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012    Succeeded
2012/10/11:14:43:01    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:43:52    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:14:43:52    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:44:12    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Content Service    Succeeded
2012/10/11:14:44:13    TRAndrews    TRANDREWSOFFICE    Installing AutoCAD LT® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI3F9E.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:00:54    TRAndrews    TRANDREWSOFFICE    Install    AutoCAD LT® 2012    Failed    Installation aborted, Result=1603
2012/10/11:15:00:58    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Content Service    Succeeded
2012/10/11:15:01:11    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:15:01:25    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012    Succeeded
2012/10/11:15:01:25    TRAndrews    TRANDREWSOFFICE    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/11:15:01:25    TRAndrews    TRANDREWSOFFICE    PageOpen    InstallCompleteDialog
2012/10/11:15:09:09    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:15:09:47    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:15:09:47    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:15:09:55    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:15:09:50    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:15:09:50    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:15:09:55    TRAndrews    TRANDREWSOFFICE    PageOpen    LaunchDialog
2012/10/11:15:10:26    TRAndrews    TRANDREWSOFFICE    PageOpen    LicenseDialog
2012/10/11:15:10:29    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductInfoDialog
2012/10/11:15:10:53    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductSelectionDialog2
2012/10/11:15:10:54    TRAndrews    TRANDREWSOFFICE    PageOpen    FullProgressDialog
2012/10/11:15:10:54    TRAndrews    TRANDREWSOFFICE    Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:15:11:14    TRAndrews    TRANDREWSOFFICE    Install    DirectX Runtime    Succeeded
2012/10/11:15:11:14    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:11:29    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012    Succeeded
2012/10/11:15:11:29    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:11:56    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:15:11:56    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:12:19    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Content Service    Succeeded
2012/10/11:15:12:21    TRAndrews    TRANDREWSOFFICE    Installing AutoCAD LT® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI5669.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:14:11    TRAndrews    TRANDREWSOFFICE    Install    AutoCAD LT® 2012    Failed    Installation aborted, Result=1603
2012/10/11:15:14:14    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Content Service    Succeeded
2012/10/11:15:14:27    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:15:14:41    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012    Succeeded
2012/10/11:15:14:41    TRAndrews    TRANDREWSOFFICE    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
