Installation & Licensing
Autocad LT 2004 intallation queries
4 REPLIES 4
329 Views, 4 Replies
I have Autocad LT 2004 and I am trying to intall that for some time without success. When I tried to register the product on https://register.autodesk.com, it has for 'REQUEST CODE' and my activation process does not generate any request code. So I am not able to registered it, is there a way to get the software install?
Tags (1)
4 REPLIES 4
Charles_Shade
Welcome to the Autodesk Forums!
Though this likely will not help with the request code what is the OS you are trying to install the 2004 on?
dembkod
ajayraut,
Hello. This is a program 10 years past development and there have been countless updates and changes to any operating system during this period. This particular program was built for Windows XP. All other systems can cause inconsistent behaviors. You could try to call our activation line: 1800 551 1490
Thank you for taking part in our community!
David Dembkoski
in reply to: Charles_Shade
what do you mean by OS, can you clarify.
Ajay Raut
TravisNave
Which version of Windows are you trying to install this onto?  It is only supported for Windows XP.  So if you are trying to install it onto Windows 7 or 8, you will probably be out of luck.
Autodesk Forums:
Administrator Productivity
