Hi, I get an install fail msg when i try and install autocad 2014 student 64bit on my HP Laptop. I have looked at previous threads on this message forum and deleted a program on my computer called microsoft .net framework client 4.0. But i still get a fail message. It is below. Please help.
2014/5/1:19:20:55 Jean JEAN-HP === Setup started on JEAN-HP by Jean ===
2014/5/1:19:20:55 Jean JEAN-HP Path_Length: 155
2014/5/1:19:20:55 Jean JEAN-HP Current Directory C:\Users\Jean\AppData\Local\Temp\_AI140C.tmp
2014/5/1:19:20:55 Jean JEAN-HP Launch
2014/5/1:19:20:56 Jean JEAN-HP Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/5/1:19:20:56 Jean JEAN-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Jean\AppData\Local\Temp\_AI140C.tmp\Setup\AcSetup.dll
2014/5/1:19:20:56 Jean JEAN-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:19:20:57 Jean JEAN-HP PageOpen LaunchDialog
2014/5/1:19:21:03 Jean JEAN-HP PageOpen LicenseDialog
2014/5/1:19:21:03 Jean JEAN-HP PageOpen ProductInfoDialog
2014/5/1:19:21:03 Jean JEAN-HP PageOpen ProductSelectionDialog2
2014/5/1:19:21:12 Jean JEAN-HP PageOpen FullProgressDialog
2014/5/1:19:21:12 Jean JEAN-HP Download Skipped DOTNET4 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/5/1:19:21:12 Jean JEAN-HP Installing .NET Framework Runtime 4.0: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe" /q
2014/5/1:19:21:27 Jean JEAN-HP Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
1603 error is fairly common.
Check out the 1603 error links in the signature line of TravisNave:
http://forums.autodesk.com/t5/Installation-Licensing/invalid-serial-number/m-p/3393445#M44015
RK is right. The problem is a 1603 error installing .NET
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
