Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Autocad Electrical 2012 won't install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having the same issues installing Autocad Electrical 2012. I've tried all the solutions here Unable to Install ACAD 2012 with no luck.
My machine is Windows 7 Home. See attached files.
Can anyone help out?
Re: Autocad Electrical 2012 won't install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
This is related to VC++ runtime error, reinstalling those componets should fix the issue.
please try
http://forums.autodesk.com/t5/Installation-Licensi
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Still doesn't work.
Whats next!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you installed all the Vc++ runtime manually. ?
Please post the logs again
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I removed Vc++ using the Control Panel after making the change in the registry.
Here's the log
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please try to install Microsoft Visual C++ 2005 Redistributable (x86) manually as described in the other post.
It is still failing on the same component.
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
All I can say is what a pain in the ****!
Finally got it installed. The Microsoft Visual C++ 2005 Redistributable (x86) kept asking for the .msi file.
Had to rename the key-name
HKEY_CLASSES_ROOT\Installer\Products\F942F94A19C0F
HKEY_CLASSES_ROOT\Installer\Products\-F942F94A19C0
and then re-run the installer.
I hope Autodesk fixes this issue in future versions.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Glad you could fix it using the registry.
I can understand your frustration, this is a Microsoft component (runtime) which gets installed with various other programs, usually cleanly uninstalling these components and reinstalling fixes the issue.
Hashim Mundol
