Hei,
I just installed Civil 3D 2011 and started trial version in order to practice on software, but I have problem on Ribbons. It simply does not load ribbon and therefore I cannot use it. Whenever I enter the command "Ribbon" it gives the error that I atteched below.
I would really appreciate if anyone could help me, thanks in advance
Try uninstall all versions of Microsoft .net Framework on your machine (Control Pane l> Add/Remove Programs) and install
the latest version of Microsoft .net Framework (versions 4) from
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992
If this does not help, try resetting user settings as per the link below:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14929107&linkID=9240697
