Installation & Licensing
New Member
helios.cro
Message 1 of 2 (105 Views)
Autocad Civil 3D failed
105 Views, 1 Replies
06-07-2013 12:29 PM
Hello everybody,
I am trying to install autocad civil 3d 2012;
problem is that i have to instal it to shared computer, where is already installed autocad maps 3d 2010;
2013/6/7:21:08:04 LocalAdmin Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\civil3d\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/6/7:21:23:13 LocalAdmin Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
What can I do solve this problem?
Thank you in advance!
*Expert Elite*
TravisNave
Message 2 of 2 (81 Views)
Re: Autocad Civil 3D failed
06-10-2013 07:41 AM in reply to: helios.cro
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
