I am atempting to install AutoCAD Civil 3D 2012 on a PC and received the follwong message:
AutoCAD Civil 3D 2012 or Map 3D 2012 must be installed for Storm and Sanitary Analysis standalone 2012 to be installed.
How do I do this?
Bryan
Here is the Setuo Log Produced:
2013/5/24:12:40:34 Shaun ENGINEER-1-PC === Setup started on ENGINEER-1-PC by Shaun ===
2013/5/24:12:40:34 Shaun ENGINEER-1-PC Launch
2013/5/24:12:42:55 Shaun ENGINEER-1-PC === Setup ended ===
2013/5/24:12:40:40 Shaun ENGINEER-1-PC === Setup started on ENGINEER-1-PC by Shaun ===
2013/5/24:12:40:40 Shaun ENGINEER-1-PC Launch
2013/5/24:12:42:56 Shaun ENGINEER-1-PC PageOpen LaunchDialog
2013/5/24:12:43:57 Shaun ENGINEER-1-PC PageOpen LicenseDialog
2013/5/24:12:44:01 Shaun ENGINEER-1-PC PageOpen ProductInfoDialog
2013/5/24:12:44:25 Shaun ENGINEER-1-PC PageOpen ProductSelectionDialog2
2013/5/24:12:45:01 Shaun ENGINEER-1-PC === Setup ended ===
2013/6/20:10:05:29 Shaun ENGINEER-1-PC === Setup started on ENGINEER-1-PC by Shaun ===
2013/6/20:10:05:29 Shaun ENGINEER-1-PC Launch
2013/6/20:10:07:42 Shaun ENGINEER-1-PC === Setup ended ===
2013/6/20:10:05:35 Shaun ENGINEER-1-PC === Setup started on ENGINEER-1-PC by Shaun ===
2013/6/20:10:05:35 Shaun ENGINEER-1-PC Launch
2013/6/20:10:07:42 Shaun ENGINEER-1-PC PageOpen LaunchDialog
2013/6/20:10:11:59 Shaun ENGINEER-1-PC PageOpen LicenseDialog
2013/6/20:10:12:04 Shaun ENGINEER-1-PC PageOpen ProductInfoDialog
2013/6/20:10:13:28 Shaun ENGINEER-1-PC PageOpen ProductSelectionDialog2
2013/6/20:10:13:48 Shaun ENGINEER-1-PC PageOpen FullProgressDialog
2013/6/20:10:13:49 Shaun ENGINEER-1-PC Installing Autodesk Storm & Sanitary Analysis 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Shaun\AppData\Local\Temp\_AIDA4A.tmp\Media.mst"
2013/6/20:10:15:05 Shaun ENGINEER-1-PC Install Autodesk Storm & Sanitary Analysis 2012 Failed Installation aborted, Result=1603
It appears you are trying to install Storm & Sanitary, not Civil 3D. Double-check your installation.
