Installation & Licensing
Active Contributor
daley1234
Message 1 of 5 (581 Views)
Autocad Architecture will not uninstall after a failed installation
581 Views, 4 Replies
12-03-2012 06:13 PM
I tried installing autocad architecture 2013 64bit on a windows 7 pc however; in the middle of the installation the electricity went and since I have not been able to re-instal or uninstal. I have uninstalled all the autocad product installed and removed registry keys but each time I tried reinstalling the products it tells you that autocad architecture is already installed and will not allow me to reinstall.
I tried one of the uninstaller but when I ran it the below error is thrown: I need help please?
Succeeded:
(None)
Failed:
FARO LS 1.1.406.58
Reason: Another installation is already in progress. Complete that installation before proceeding with this install.
Autodesk Design Review 2013
Autodesk Inventor Fusion 2013
Autodesk Material Library 2013
Autodesk Material Library Base Resolution Image Library 2013
Autodesk Content Service
TravisNave
Message 2 of 5 (562 Views)
Re: Autocad Architecture will not uninstall after a failed installation
12-04-2012 07:51 AM in reply to: daley1234
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Contributor
daley1234
Message 3 of 5 (551 Views)
12-04-2012 05:28 PM in reply to: TravisNave
Thanks for the response,
However; I have tried all the suggestions and tools you recommended but none worked. I am still unable to install autocad architecture 2013 64bit. Once I start the installation it tell shows me that autocad architecture is already installed although the installation is nowhere to be found on the PC.
TravisNave
Message 4 of 5 (531 Views)
12-05-2012 07:36 AM in reply to: daley1234
You might have to traverse the registry and find the key that contains the product.  I recommend starting here in regedit and drilling down:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\
Active Contributor
daley1234
Message 5 of 5 (519 Views)
12-05-2012 07:02 PM in reply to: daley1234
I was finally able to remove all registry keys and reinstalled autocad
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
