• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Autocad Architecture 2013 Installation on new Windows 7 PC
    251 Views, 3 Replies
    10-30-2012 01:29 PM
    I'm trying to install my software and it says "System update required. Your computer is using an unsupported version of the Microsoft.NET Framework. The product you are installing requires Microsoft.NET Framework 4.0 or later", then it says to update the software, restart and install.
    The problem is, I can't get any 4.0 or 4.5 or other version of this software to install on my machine.  I try and I get an error code HRESULT 0xc8000222, and the install wasn't successful.  I've never encountered this type of error/conflict with Autocad before.  Any suggestions out there? (I need to get workin!)
    Attached are screen shots of the error messages I'm getting.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Autocad Architecture 2013 Installation on new Windows 7 PC
    10-30-2012 01:46 PM in reply to: yumij
    You might have to use the .NET Framework cleanup tool.
    .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    10-30-2012 02:57 PM in reply to: TravisNave
    I tried the cleanup tool and then tried to reinstall the software - same exact thing happened.  I see that when this conversation was moved that this part of the conversational thread was removed.  I think its important to note this for other users - there's a problem here and I'm not sure that this is all Window's fault.  I've got a new machine out of the box that I'm installing this on... this shouldn't be that hard.
    The last note from the discussion board was to check to see if WIndow's Update will fix this.  Window's doesn't recognize an issue here, I'm all up to date.  I tried installing 4.0 and 4.5, no luck.  I'm simply not able to install either NET package on my system successfully and it doesn't show that its currently installed on my computer either when I look at my list of current programs.
    *Expert Elite*
    TravisNave
    10-30-2012 03:05 PM in reply to: yumij
    You're actually responding between two separate threads.  Nothing was lost:
    As for the issue, if .NET Framework will not install, it has absolutely nothing to do with Autodesk software.  The .NET Framework is a Microsoft product, as is Windows.  Both are prerequisites for the Autodesk software to even start the installer.  Clearly, there is something preventing the .NET to be installed on your system.  You might have to open a trouble ticket with Microsoft.
    Travis Nave
