Installation & Licensing
Autocad Architecture 2011 install problem on Windows Vista 64 Bits
1 REPLY 1
463 Views, 1 Reply
I want to install Autocad Architecture 2011 64 bits on my Windows Vista 64 Bits, but after setup check the internet connection for service packs the instalation hangs with the following error "data execution prevention has closed autodesk component". I already deactivate DEP for all process and program but didn't work either.
Can someone tell me how to fix the problem please?
Thanks! Edited by: caceresmartin on Apr 22, 2010 3:15 PM
1 REPLY 1
TravisNave
Since there are no updates, try disconnecting from the Internet and try installing again as a test to see if it crashes without a network connection.
Autodesk Forums:
Administrator Productivity
