Installation & Licensing
New Member
kevin
Message 1 of 4 (145 Views)
Autocad Architecture 2010 License Transfer
145 Views, 3 Replies
09-05-2013 02:45 PM
My computer has a flaky motherboard.  We thought we were going to be able to export the license out of that computer with the LTU and into this new computer.  However, when i put in the Serial number to export, it says it is not valid.
I have tried to activate the new install on the new computer and to the same error.  The serial number you entered is not valid. Try again. (1)
I think this is due to our subscription running out on the product, but I am just trying to deactive the license on a bad machine and send it to a new machine.  The old machine will be recycled, after I get migrated off of it.
What should my next step be?
DarrenP
Message 2 of 4 (143 Views)
Re: Autocad Architecture 2010 License Transfer
09-05-2013 02:59 PM in reply to: kevin
yes it could be because your subscription expired
and that 2010 serial number was upgraded to something else
you can try this way: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20119851&linkID=9240617
New Member
kevin
Message 3 of 4 (124 Views)
09-06-2013 03:53 AM in reply to: kevin
I can not use this method, as it still says my serial number is not valid.  I have checked with the orginal packaging, and it is correct.  I have the request code but can go no further as it alway error on my serial number.
It does not matter if I use the activate on the product or website, same issue.
camilo.lemos
Message 4 of 4 (118 Views)
09-06-2013 04:34 AM in reply to: kevin
Hi Kevin,
As DarrenP mentioned above, it is likely that your product has been upgraded to a newer version. Please, send me your serial number via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) so that I can verify this for you and we can then proceed to activate your software.
Thank you,
Camilo Lemos
