i have configure network license on server sucessfully but when i m installing on client giving the server name, it was not taking and next tab is non higlighted. this server is on different VLanes ports. please help me on this issue.
You can type the server name in and it will work.
Then use IP address or pick any other server listed. It doesn't matter because you can change the LICPATH.LIC file after install or create an ADSKFLEX_LICENSE_FILE system environment variable to override the installation setting.
