• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Autocad 2013 will not install ... subscription wont work either
    131 Views, 1 Replies
    02-04-2013 11:18 AM
    My installation took the seral number and product code OK, but it will never start ... it always gets hung up on a splash screen with the word  "initializing ....".   Tried reinstall, erase, reinstall  ad infinitum.   Bought subscription from Ideate in San Francisco, with the hope that I would get more technical support.  Nope .... autodesk does not even have a record of the subscription.   This may be the worst system for customer support I've ever seen.   I get a whole lot more support when I buy a $39 router from Netgear.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Autocad 2013 will not install ... subscription wont work either
    02-05-2013 11:46 AM in reply to: ehiskes
    Post your installation log file here and maybe it'll help figure out the problem.
    In the meantime, get a new reseller.
    http://usa.autodesk.com/adsk/servlet/ps/details?siteID=123112&catID=1078762&configID=1088201&partner...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
