• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    tnw
    New Member
    Autocad 2013 failure to install
    92 Views, 1 Replies
    02-13-2013 10:47 AM
    2013/2/7:21:01:22    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
    2013/2/7:21:01:22    Home    HOME-VAIO    Launch
    2013/2/7:21:01:24    Home    HOME-VAIO    === Setup ended ===
    2013/2/7:23:55:38    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
    2013/2/7:23:55:38    Home    HOME-VAIO    Launch
    2013/2/7:23:55:49    Home    HOME-VAIO    === Setup ended ===
    2013/2/13:10:43:13    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
    2013/2/13:10:43:13    Home    HOME-VAIO    Launch
    2013/2/13:10:43:18    Home    HOME-VAIO    === Setup ended ===
    2013/2/13:10:43:14    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
    2013/2/13:10:43:14    Home    HOME-VAIO    Launch
    2013/2/13:10:43:18    Home    HOME-VAIO    PageOpen    LaunchDialog
    2013/2/13:10:43:22    Home    HOME-VAIO    PageOpen    LicenseDialog
    2013/2/13:10:43:26    Home    HOME-VAIO    PageOpen    ProductInfoDialog
    2013/2/13:10:44:09    Home    HOME-VAIO    PageOpen    ProductSelectionDialog2
    2013/2/13:10:44:27    Home    HOME-VAIO    PageOpen    FullProgressDialog
    2013/2/13:10:44:27    Home    HOME-VAIO    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
    2013/2/13:10:44:29    Home    HOME-VAIO    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1603
    That is the install log, can anyone help me out?
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Autocad 2013 failure to install
    02-14-2013 08:25 AM in reply to: tnw
    Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
    For more information about this process, please see my KB link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    Good Luck!
