Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autocad 2013 failure to install
- Highlight
- Email to a Friend
2013/2/7:21:01:22 Home HOME-VAIO === Setup started on HOME-VAIO by Home ===
2013/2/7:21:01:22 Home HOME-VAIO Launch
2013/2/7:21:01:24 Home HOME-VAIO === Setup ended ===
2013/2/7:23:55:38 Home HOME-VAIO === Setup started on HOME-VAIO by Home ===
2013/2/7:23:55:38 Home HOME-VAIO Launch
2013/2/7:23:55:49 Home HOME-VAIO === Setup ended ===
2013/2/13:10:43:13 Home HOME-VAIO === Setup started on HOME-VAIO by Home ===
2013/2/13:10:43:13 Home HOME-VAIO Launch
2013/2/13:10:43:18 Home HOME-VAIO === Setup ended ===
2013/2/13:10:43:14 Home HOME-VAIO === Setup started on HOME-VAIO by Home ===
2013/2/13:10:43:14 Home HOME-VAIO Launch
2013/2/13:10:43:18 Home HOME-VAIO PageOpen LaunchDialog
2013/2/13:10:43:22 Home HOME-VAIO PageOpen LicenseDialog
2013/2/13:10:43:26 Home HOME-VAIO PageOpen ProductInfoDialog
2013/2/13:10:44:09 Home HOME-VAIO PageOpen ProductSelectionDialog2
2013/2/13:10:44:27 Home HOME-VAIO PageOpen FullProgressDialog
2013/2/13:10:44:27 Home HOME-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdPart
2013/2/13:10:44:29 Home HOME-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
That is the install log, can anyone help me out?
Re: Autocad 2013 failure to install
- Highlight
- Email to a Friend
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensi
Good Luck!
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
