Installation & Licensing
tnw
New Member
tnw
Message 1 of 2 (140 Views)
Autocad 2013 failure to install
140 Views, 1 Replies
02-13-2013 10:47 AM
2013/2/7:21:01:22    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
2013/2/7:21:01:22    Home    HOME-VAIO    Launch
2013/2/7:21:01:24    Home    HOME-VAIO    === Setup ended ===
2013/2/7:23:55:38    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
2013/2/7:23:55:38    Home    HOME-VAIO    Launch
2013/2/7:23:55:49    Home    HOME-VAIO    === Setup ended ===
2013/2/13:10:43:13    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
2013/2/13:10:43:13    Home    HOME-VAIO    Launch
2013/2/13:10:43:18    Home    HOME-VAIO    === Setup ended ===
2013/2/13:10:43:14    Home    HOME-VAIO    === Setup started on HOME-VAIO by Home ===
2013/2/13:10:43:14    Home    HOME-VAIO    Launch
2013/2/13:10:43:18    Home    HOME-VAIO    PageOpen    LaunchDialog
2013/2/13:10:43:22    Home    HOME-VAIO    PageOpen    LicenseDialog
2013/2/13:10:43:26    Home    HOME-VAIO    PageOpen    ProductInfoDialog
2013/2/13:10:44:09    Home    HOME-VAIO    PageOpen    ProductSelectionDialog2
2013/2/13:10:44:27    Home    HOME-VAIO    PageOpen    FullProgressDialog
2013/2/13:10:44:27    Home    HOME-VAIO    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/13:10:44:29    Home    HOME-VAIO    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1603
That is the install log, can anyone help me out?
TravisNave
Message 2 of 2 (121 Views)
Re: Autocad 2013 failure to install
02-14-2013 08:25 AM in reply to: tnw
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
