• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Autocad 2013(64bit) Communication Failure when installing
    1673 Views, 5 Replies
    12-03-2012 03:17 PM
    does any know one how to solve this problem? reply as soon as possible please
    i blocked all the security but still not working, it worked when i first installed it like 2 3 weeks ago
    see the attachment
    Please use plain text.
    Re: Autocad 2013(64bit) Communication Failure when installing
    12-03-2012 04:56 PM in reply to: masif11
    TravisNave
    12-04-2012 08:21 AM in reply to: masif11
    You might try deleting any previous download from C:\Autodesk and try again.  Make sure you aren't running any Norton Internet Security or other handicapping software.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    12-04-2012 01:41 PM in reply to: mr-_-small
    where can i find windows net framework all 4 and 3.5? and windows installer? do you know any links?
    thanks
    TravisNave
    12-04-2012 02:26 PM in reply to: masif11
    Search for them here as the links will be dependent on your host OS:
    http://www.microsoft.com/en-us/download/default.aspx
    Travis Nave
    Member
    12-04-2012 03:01 PM in reply to: TravisNave
    ok i tried browser download, half way throught i get an error regarding Autodesk content service 2738.:smileyfrustrated:
