We're trying to deploy Autocad 2012 silently through SCCM 2007 SP3. The installation is 64 bits running on 64 bits Windows 7 boxes. When deployed, the installation works fine and everything gets installed, but the original setup.exe quit almost instantly, with the remaining msis still running in the background. This is a problem for us as other programs then try to get deployed, but since the installation is still running, they fail and we're not able to get the correct exit code for the autocad installation either.
Is there a way to get the process to stay on as long as the installation is not completed and to return the correct exit code to SCCM?
PS : Here's the installatio command we're running : %~dp0setup.exe /qb /I %~dp0ACAD2012_64FR.ini /language fr-fr
Hi and welcome to the forum. I think you need to put a /w in there to make it wait. So you could use %~dp0setup.exe /qb /w /I %~dp0ACAD2012_64FR.ini /language fr-fr
