• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    sm4rt
    Autocad 2011 Installation trouble error 1603
    22225 Views, 22 Replies
    06-19-2010 12:08 PM
    Hi !
    I got a situation when trying to install Autocad 2011 on my PC. The installation failed on Microsoft Visual C++ installation which return the error code 1603 !
    here is the log installation file :
    2010/6/19:11:28:01	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
    2010/6/19:11:28:30	Desktop	MYCOMPUTER	=== Setup ended ===
    2010/6/19:11:28:20	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
    2010/6/19:11:31:24	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
    2010/6/19:11:32:34	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2008 Redistributable (x86)	Failed	Installation aborted, Result=1603
    2010/6/19:11:34:31	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
    2010/6/19:11:35:32	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
    2010/6/19:11:35:46	Desktop	MYCOMPUTER	=== Setup ended ===
    2010/6/19:11:37:21	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
    2010/6/19:11:37:30	Desktop	MYCOMPUTER	=== Setup ended ===
    2010/6/19:11:37:26	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
    2010/6/19:11:38:44	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
    2010/6/19:11:38:54	Desktop	MYCOMPUTER	=== Setup ended ===
    2010/6/19:11:43:17	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
    2010/6/19:11:43:27	Desktop	MYCOMPUTER	=== Setup ended ===
    2010/6/19:11:43:23	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
    2010/6/19:11:47:47	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
    I'm currently on an ASUS Windows 7 with an AMD Athlon II Dual-Core M320 2.1GHz processor.
    Please help me to solve this probleme
    regards
    Please use plain text.
    TravisNave
    Re: Autocad 2011 Installation trouble error 1603
    06-21-2010 08:16 AM in reply to: sm4rt
    You might consider installing the Visual C++ 2005 prerequite separately first by downloading it from Microsoft.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    06-23-2010 07:14 AM in reply to: sm4rt
    I have had a similar problem which I discussed in another thread (see Installing Maya (ERROR = 1603) Windows 7). Unfortunately I have been attempting to install on a Windows 7 PC for over a month now and have not found a solution yet. The Autodesk support rep has offered some suggestions but none have resolved the issue. I can tell you that in my case, simply installing the prerequisites, upgrading the prerequisites, or un-installing and re-installing the prerequisites did not work. I am extremely frustrated with this problem. Have spent numerous eveings and countless hours trying to resolve. My opinion is this might be a Version 2011 installation bug related to some Windows 7 systems. I had installed Civil 3D 2010 on this same PC without a problem. I have installed many programs on this PC without any difficulties. In my case the installation routine aborts when trying to install Visual C++ 2008 Redistributable (x86) regardless of whether it is already there or not installed. It should not be this difficult to install a program. Any assistance would be greatly appreciated.
    Product Support
    06-28-2010 02:47 PM in reply to: gregdillan5026
    Typically the 1603 error has several potential solutions. I am a fan of going straight to the Diagnostic Startup mode as it covers several causes with one stone:
    1. Microsoft Installer documentation lists that the 1603 indicates a resource needed by the installer is in use by another process. Often a reboot will stop this. Quitting background applications during the installation of an application is a best practice.
    2. Bad media, dirty lens, bad optical drive or bad optical drive drivers can all cause this. If you downloaded the 2010 or 2011 product and it extracted to the C:\Autodesk (or your designated) folder. This should not be the case. You can restart the installer from the Setup.exe without need to re-extract the installer from the download. If you are trying to install from the DVD copy the contents to a temp folder on the local hard drive. If there are several disks start with the first disk then copy additional disks, in order, into the same location and overwrite any files if asked.
    3. Permissions are sometimes associated with this error. For Windows Vista and Windows 7 try disabling UAC. Make sure you are a Local Administrator. Sometimes a Domain Admin needs to be added to the local Administrators group. Right-clicking the setup.exe and choosing to Run as Administrator may be necessary as well.
    Douglas Lauritsen
    Support Specialist
    Product Support
    New Member
    jjakel
    07-08-2010 09:15 AM in reply to: sm4rt
    I have disabled UAC and run as an administrator and I still get the 1603 error.  I installed Visual C++ 2008 redist SP1 from MS and that works fine.  However the ACAD install does not see that this is installed and still tries to install its version of the redist and it fails with 1603.
    New Member
    psafavie
    07-11-2010 10:28 AM in reply to: jjakel
    New Member
    jjakel
    07-12-2010 08:13 AM in reply to: sm4rt
    I solved this issue.  If you have Arc GIS 9.3.1 installed on a windows 7 Machine it can reach the registry size limit.  ACAD 2011 will not be able to install passed Visual C++ redist.  Set your registry size limit to infinite and reboot.
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
    Key: RegistrySizeLimit
    Type: REG_DWORD
    Value: 0xffffff (4294967295)
    Hope this helps.
    New Member
    PWJVoorwinde5094
    07-15-2010 01:31 AM in reply to: sm4rt
    I had placed a copy of the install dvd on my HD and ran setup from HD. This gave me a 1603 error and i could not install 2011 on my windows 7 pro OS. I retried by installing directly from dvd in stead of HD copy and this worked like a charm.
    Member
    silver_moon525
    08-08-2010 12:36 PM in reply to: PWJVoorwinde5094
    Not to redig up this thread, but I am also having this problem, except with Maya 2011.
    I've tried ALL of the suggestions above and nothing worked.
    Am I doomed to never use Maya on this computer forever??? =(
    New Member
    idlewildbrooklyn
    09-30-2010 07:43 PM in reply to: sm4rt
    Beautiful!  I had the same issue and had ArcGIS 9.3.1 on my computer, altering the registry worked for me too.  Thanks for posting, it really helped.
